Lexmark paper jam
  • PA3040
    • Jun 2014
    • 171
    Lexmark paper jam
    Dear all
    I have Lexmark S405 Interpret Priner
    Isse
    It display is showing Paper Jam!
    I carefully checked it when I send the print its feed only one inch and get paper jam
    as well as when I power on it is showing paper jam the I pressed the START key then jam disaper
    Please advice
  • subaro
    • Oct 2010
    • 1274
    Re: Lexmark paper jam
    So what did you actually do in terms of trying to improve feeding the paper?. There is basics in troubleshooting paper feeding problems that a tech is expected to perform. Let's try by cleaning the pickup rollers and feed paths. demonstrate that you have actually done something.
    • PA3040
      • Jun 2014
      • 171
      Thanks for the reply
      I have two printers both are same model
      In the first attempt I cleaned the pick up rollers and then i changed the feeding unit with other printer then I changed the feed sensor but problem is remaining same
      My point is.... when I switch ON the machine, it is initialing and then paper jam is displaying
      I do not have service mode to test sensors
      please advice to find out fault
      thanks in advance
      • subaro
        • Oct 2010
        • 1274
        thanks in advance
        This is a cheap inkjet machine i see listed for 130 dollars, so i doubt you will find and service manuals for this machine to test the sensors. In fact this may have only one sensor for paper detection and will use an encoder disk for paper feed monitor, aslo encoder strip for carriage movement detection. If you changed the feeding unit, then there is only one thing left, that is the mainboard, as the feeding unit would usually have the paper detect sensor. Don't really know this machine personally, but most inkjet functions the same way. you will have to be intuitive in troubleshooting this. Inkjets are messy repairs.
        • subaro
          • Oct 2010
          • 1274
          Actually, there is a service manual and firmware update for this machine.
          • PA3040
            • Jun 2014
            • 171
            Hi
            Firmware has been updated
            Where can I find the Service manual
            • subaro
              • Oct 2010
              • 1274
              Hi
              when you click on partner log-in, if you have dealer login.
              • PA3040
                • Jun 2014
                • 171
                http://support.lexmark.com/index?pag...erlocale=EN_US
                Dear All,
                My Printer is displaying "Preparing Printer.... " Please advice to solve this issue
                Thanks in advance
                • Lance15
                  • Jun 2015
                  • 1086
                  Like subaro said....it's a cheap inkjet. Let it go. Move on...........
                  If the customer really wants it fixed, you'll have to figure it out. Like us real tech's, you'll figure something out.
