Lexmark E260dn ready light is red on power
  • Orion2010
    • Jun 2015
    • 176
    I have an lexmark e260dn with the ready light showing a solid red light when the printer is turned on. Printer doesnt warm up, there are no noises coming from it, and the PC doesnt even recognize it trough the USB...
    Help, please?
  • Lance15
    • Jun 2015
    • 1089
    Re: Lexmark E260dn ready light is red on power
    If you double-click the Continue button (green button with the "Play" icon), does it show another light pattern?
    • Orion2010
      • Jun 2015
      • 176
      only red
      • Elmtech
        • Nov 2013
        • 155
        Would guess electronic issue. Main PCB, LVPS etc.
        • ZOOTECH
          Senior member of CRS
          • 3375
          Originally posted by Orion2010
          only red
          Are you able to get into diagnostic mode (usually holding down the 3 and 6 when powering up)?
          There you can get a fault log that may point to the problem.
          • Lance15
            • Jun 2015
            • 1089
            The E260 doesn't have a "num pad". Only two buttons (Continue & Cancel).
            It looks like a fatal error. I'm thinking formatter.
            Does this unit have an accessory tray installed? If it does, remove it. Get it down to the base unit. Remove all cables except the power cable.
            I've seen where accessory trays cause problems.
            • ZOOTECH
              • 3375
              Thank you, I don't have a current manual.
              • alinc2016
                • Nov 2016
                • 15
                Which of the lights is on?
