MX611de with error 111.30 ("printhead error")
  • axyun
    • Aug 2007
    • 1323
    Customer dropped off MX611de with error 111.30. Says printhead error. I am in the meantime searching SM download
    but wondering if just a supply item problem like drum or toner cartridge identification. Any information is very much appreciated. Frank
    Re: MX611de with error 111.30 ("printhead error&quot
    nope..it's the printhead ( laser - LSU )
    • axyun
      • Aug 2007
      • 1323
      Thank you Phil. I forgotto mention that hen customer called he said he had a lift motor error #146. When he brought macine to me I did id not see the error #146 bit only the 111.30 after turning on machine during warmup cycle. Thought I would mention in case it has significance. Frank
      • axyun
        • Aug 2007
        • 1323
        Just one other question Phil. What is the possibility that it is controller board and not LSU as mentioned in SM?
          i've never had that be the issue... always been LSU
          • axyun
            • Aug 2007
            • 1323
            Thanks again Phil.
            • axyun
              • Aug 2007
              • 1323
              HI Phil Sorry to bug you again. I ordered the LSU which supposedly was 40X8079. It Looks different in shape from one in machine. The one in machine
              has a 12 pin connector and a 5 pin connector whereas the new one has 10 pin connector as well as a 7 pin connector. The machine I am working on
              says MX611DE. The front door when opened has label that says 7016-670 and ser #7016 5PHH 06PZ2 The back label says Model 040J MX611DE.
              The LSU in machine has label that says 35S4420. New one says 35S3553. In meantime I will contact Item Inc where I purchase LSU to see if
              they can shed some light on this problem. Thank you for your assistance. Frank
                there are 2 LSU's for those models IF I remember correctly. talk to Whit he should work with you on this
                • Lance15
                  • Jun 2015
                  • 1077
                  Nah. This is a mono machine. One LSU.
                  • axyun
                    • Aug 2007
                    • 1323
                    I think Phil means some models were using one version of LSU and some used another. Frank
                    • Lance15
                      • Jun 2015
                      • 1077
                      Gotcha.
                        no Sir there are TWO different models of the MONO LASER for this machine.. you have to determine the proper LSU via the serial number.
