Lexmark X746de color calibration
  • Ricky965
    • Mar 2008
    • 36
    Replaced all the toners in the machine. All colors have streaks in them. Ordered a new transfer belt as it has streaks in it. This was not a good investment. Glad I have a larger color Ricoh ij the shop for printing.
    • 22999
    Re: Lexmark X746de color calibration
    It's not uncommon for new Lex toner cartridges to display mottling. I think it may even diminish with use. Just look at the developing roller. You'll know immediately. =^..^=
    • Thayer
      • Dec 2017
      • 107
      Did you replace the photo conductors??
      You said you replace the toners!
      • dalewb74
        • Feb 2018
        • 1125
        very common issue i see a good bit with those toners. usually replace it and it works again for awhile. don't know if an actual fix. first time it happened thought it was the drum, but learned later from another tech. it's the bad toners.
