Lexmark MX-410 no transfer
  • theengel
    • Nov 2011
    • 1784
    I've got a machine that is not transferring. I swapped the transfer roller with one from another machine and there was no change. Would the power supply be next in line?
  • driving lots of miles
    • Jun 2016
    • 395
    Re: Lexmark MX-410 no transfer
    I assume you have tried a new image unit, after that there is not much use to spend time or effort as it is getting cost prohibitive to do much more. These boxes are throwaway.
    • tsbservice
      Field tech
      • 7917
      Had once one KM 4050 which may be the same if I'm not mistaken. If you have blank print/copy try to change IU. It was the culprit in my case.
      Good luck
      • Lance15
        • Jun 2015
        • 1077
        Not transferring as in no image? How about a half-print test? Any image on the IU(s)?
          contacts in good shape?
          yeah they are the cheaper line
          they aren't using remans are they... had a cust using a China brand most were leaks..did have some FTP
          • theengel
            • Nov 2011
            • 1784
            You get a light image on the paper, when you do a stop test, you find that much of the image didn't transfer. That's what I mean by no transfer.
            • Lance15
              • Jun 2015
              • 1077
              Just realized this is a B&W unit.....duh!
              Is the Imaging Unit okay? Worked on one of these last week and right after I updated the firmware, I started getting image defects from the same imaging unit that was in the machine when I arrived. Junk IU's.
              • theengel
                • Nov 2011
                • 1784
                Cust tried the imaging unit before I got there. But again, the drum has the image on it. It's just not transferring.
                • Lance15
                  • Jun 2015
                  • 1077
                  Gotta suspect the transfer roller or power supply (combo LV & HV).
                    Ok.. then check the contacts..they used to be one assmy to the brds once I get to my paper I check the manuals... do you have them? If not..get with me.
                    • Lance15
                      • Jun 2015
                      • 1077
                      I would think the contacts would be okay. Lexmark redesigned them to be inside a plastic "carrier". Unlike the exposed contacts in like the E460 series. These contacts got squashed and bent all the time.
