Lexmark ms811dn fuser reset?
  • mrfuser
    • 1617
    Re: Lexmark ms811dn fuser reset?
    man don't you ever BUY/LOCATE SM for the units you work on?
    would expedite your service calls and would the need for you to post these type posts!
    • mrfuser
      • 1617
        0 rep power
        many many red cards
        I HELP People that put forth an effort to show they tried.
        you had the manual and didn't take it with you?
        did you leave your screw driver 'back at the office' also?
        part of being a competent tech is to follow the BSA rule " ALWAYS BE PREPARED "
        get the idea?
        • mrfuser
          • 1617
          0 rep power
          many many red cards
          get the idea?
          • tsbservice
            Field tech
            • 7991
            My oh my, Kelly strikes again
            mrfuser, can you ever stop this type of nonsense
            • mrfuser
              • 1617
              • Crusher
                • Jan 2018
                • 17
                Fuser must be replaced new.
                There is no fuser reset its built into fuser like a one time fuse.
                Fuser/Maintenance End of Life Statement from Laserpros.com below.
                Lexmark M5155, M5163, M5170, MS810, MS811, MS812, MX710, MX711,
                MX810, MX811, MX812, XM5163, XM5170, XM7155, XM7163, XM7170
                NOTICE:
                After 40X7743/40X8420 fuser/maintenance kit has reached its End of Life (EOL), the printer
                will stop functioning and fusing assembly will need to be replaced. This is controlled by a
                function built-in to the fuser by the Original Equipment Manufacturer (OEM) to track page
                count.
                Prior to 40X7743/40X8420 reaching its EOL, the following 80.xy or Scheduled Maintenance
                error messages will be received via the control panel:
                80.0x "Replace Maintenance kit"—nearly low
                80.1x "Replace Maintenance kit"—low
                80.2x "Replace Maintenance kit"—very low, 2000 estimated pages remain
                80.3x "Replace Maintenance kit"—low, 0 estimated pages remain
                80.4x "Replace Maintenance kit"—very low, 0 estimated pages remain
                These messages are not indicators of a fuser error, but rather warning the customer that the
                fusing component is reaching or has reached its EOL. Customers receiving these errors must
                purchase a replacement 40X7743 fusing assembly or 40X8420 maintenance kit.
                Please visit our website Laser Pros International | Laser Printer Parts or call 715-369-5995, Option 1 to order a
                • mloudy
                  • Oct 2015
                  • 780
                  Haven't seen it often but we have encountered the PM message remain after installing a new OEM Lexmark PM kit in this series.
                  I have been able to replace the reset chip in the those fusers to make them reset the message.
                  40G4135 Fuser RESET chip For lexmark MX7155 MS810 MS811 MS812 MX710 MX5236 USA | eBay
