Lexmark CX532adwe - Duplex problem
  • harps05
    Field Service Engineer
    • Mar 2012
    • 112
    Hi all,
    Have a Lexmark CX532adwe (1,100 pages). Has a problem duplexing. It prints the page front and back pages correctly. But when it is exiting after printing the rear side it gets about halfway out, hesitates then takes it back in about a centimeter and registers a 231.15a jam. When the page is removed it has printed perfectly, it's just that it wants to take it back in after, what should be, completion. This is a job that was assigned to us and the parts provided, and fitted were an exit sensor and the inner deflector on the inner front door. This failed to resolve the problem. Any ideas? Lexmark's are not a brand that we specialize in.
  • Keli
    • Mar 2023
    • 9
    Re: Lexmark CX532adwe - Duplex problem
    Relatively new model. Never encountered any serious problems.
    But try to do what is described in the article.
    Article
    • dalewb74
      • Feb 2018
      • 1139
      update firmware?
      • Charfamine
        • May 2020
        • 14
        Did you find a solution as I'm facing the same problem on a XC2335??
        • harps05
          • Mar 2012
          • 112
          In the end, it ended up being that the surface the printer was on was not totally flat. It was on a filing cabinet that had a slight bow in it. I sat it on a completely solid and flat bench, problem resolved. It does state in one of the manuals to ensure the printer is on a flat surface, I guess that's why.
