Lexmark C925DE Color Banding...unreal
  • tech07
    • Aug 2008
    • 409
    [CQ] Lexmark C925DE Color Banding...unreal
    Ok gentlemen. Went to a Lexmark C925 DE printer today. Call was for copy quality. Boy was that true. See attached image. Has anyone seen this wierd color banding ??2013-05-03 16.09.28 lexmark.jpg
  • JustManuals
    • Jan 2006
    • 9838
    Re: Lexmark C925DE Color Banding...unreal
    Paul@justmanuals.com
    • Iowatech
      Not a service manager
      • 3930
      Kind of looks like an automatic line adjustment/color registration pattern. Is the transfer belt unit in good shape?
      • tech07
        • Aug 2008
        • 409
        Took transfer belt out and examined. Did't see any issues ( doesn't mean there's not any). It cleans good. Can you turn line adjustment off/on.. How would you trouble shoot this. Lexmark is sending new image units, but I dont believe all three color units would go bad at once. The spacing on the bands is 75 mm..I dont see 3 print heads screwing up at the same time either.. This printer only has 24K prints..
        • Silvertoast
          • Feb 2010
          • 270
          i would try the simple first and update the firmware or reflash if it already has the newest. if still acts up u might have a sys card problem
            • 22997
            It looks like transfer belt to me too. On other brands I've seen a torn or pierced belt snag on the transfer cleaning blade, creating the bar crossfeed for each color, and offsetting the color registration by 5 to 8mm each time. Just rotate through a couple full rotations of the belt. The damage is usually pretty catastrophic, and you'll feel it in the drive when the rough spot goes by. =^..^=
            • tech07
              • Aug 2008
              • 409
              may have found a solution . http://support.lexmark.com:80/lexmar...le=EN&id=TE533
              • tech07
                • Aug 2008
                • 409
                SOLVED...Exchanged all 3 color imaging units one at a time...Cyan unit fixed it
                • Iowatech
                  • 3930
                  I would have never thought that one damaged color drum could cause CYM copy defects. Thanks for the info!
                  • Lagonda
                    • Aug 2008
                    • 1649
                    Good Morning Gentlemen,
                    Its not often I visit this corner of CTN but I have a X925 in the workshop thats giving me grief.
                    It started with the above problem and a new yellow drum unit solved the problem. Now I can't get the yellow into registration with the other colours. Tried another yellow unit but no difference and there is not enough adjustment in the manual colour registration adjustment to bring it into line.
                    With the other major brand I usually work with I would access the service programme and adjust the timing for the yellow drum motor but this feature doesn't appear to be available with Lexmark.
                    Any suggestions?
                    I tried the Lexmark helpline but after firmware and another drum unit the best they could come up with was try another toner, shesh!!!! I asked them to explain to be how a toner could affect the drum timing but they have yet to get back to me.
                    • Iowatech
                      • 3930
                      Any suggestions?
                      I might not be the fullest toner cartridge here when it comes to Lexmarks, so feel free to ignore this.
                      Still, I'd check the color registration sensors to make sure they were clean. Also, the yellow laser, too.
                      • Lagonda
                        • Aug 2008
                        • 1649
                        Yes, I've tried to not learn too much about them as well, but this box is taking up space in my workshop and won't go away. I eventually found the rego/ID sensors and gave them a clean but still no change. And as part of my fast learning curve on this disaster I'Ve discovered that they dont have lasers but a LED strip above each drum.
                        • Iowatech
                          • 3930
                          Whoops, sorry about that!
                          On the other hand, this would suggest that there was a problem with the yellow drum drive, especially in the new yellow drum unit that you recently installed. Or, somewhat less likely that the LED assembly is out of position. But I imagine you've already checked those.
                          If possible, you might try starting a new post, as it appears that the more experienced Lexmark people have moved on. No need to listen to me bringing up the basics here when it probably won't help.
                          • Lagonda
                            • Aug 2008
                            • 1649
                            Where did they move onto? Canon, Minolta, Ricoh?
                            • Iowatech
                              • 3930
                              They are probably still on the Lexmark thread.
                              It's just that, while I don't have a lot of experience on Lexmarks, I have worked on color machines for a while, and I had a couple of general purpose suggestions that I thought might help.
                              As I didn't see any other Lexmark tech replies afterwards it looked like either I need to go away or if you start a new thread they would be more likely to give you the right answer.
