C920 - how to remove the 80 fuser life warning message
Re: C920 - how to remove the 80 fuser life warning message
power off copier. hold down 2 and 6 and and turn power on (keep holding the 2 and 6) depending on your model it might be the down arrow and the right arrow you need to hold down)
To enter the configuration menu, POR the printer holdingdown the V key and the RIGHTUP and DOWN keys, and then pressing the key to select the item.
Originally posted by Dijan
To enter the configuration menu, POR the printer holdingdown the V key and the RIGHT key until the operator
panel displays “Performing Self Test”. The configuration menu can be navigated by pressing the UP and DOWN keys, and then pressing the key to select the item.
Thanks for the answer.
I knew this configuration Menu and nothing about FUSER COUNTER RESET.
It's said reset the printer internal counter for
I reset the main counter in the CONFIGURATION MENU .
This is the only counter in the CONFIGURATION MENU .
I have accessed a new menu WITH 2 AND 6
ALIGMENT MENU
AUTO ALIGN TEST
CYAN
YELLOW
MAGENTA
PRINT TEST
HARDWARE TEST
EVENT LOG
DEVELOPMENT MENU
BOOT DEVICE
AUTO NOTIFY
DEBUG CONTROL
DEBUG PORT
PRINT HISTORY
DEFAULT
US
NON US
LIGHT QUANTITY
PAGE COUNT
PRT COLOR PG COUNT
PRT MONO PG COUNT
PERM PAGE COUNT
SERIAL NUMBER
MODEL NUMBER
CONFIGURATION ID
RESET COLOR CAL
Nothing help me in this menu, I have tried and browsed throughout the menu.
Originally posted by lavoiejr
thanks for the answer.
I knew this configuration menu and nothing about fuser counter reset.
In the service manual lexmark c920 page 78[ATTACH=CONFIG]22447[/ATTACH]
it's said reset the printer internal counter for
i reset the main counter in the configuration menu .
This is the only counter in the configuration menu .
the fuser as well as the transfer belt have fuseable links in them. if you are using a new fuser from Lexmark contact tech support for replacement if its a refurbished fuser odds are that the link wasn't replaced durning build up.
