C920 - how to remove the 80 fuser life warning message
  • lavoiejr
    [Error Code] C920 - how to remove the 80 fuser life warning message
    Any help, will be appreciate
    I changed the fuser and the message did not dissapear.
    I reset the main count value.
    I reset factory defaults (basic)
    The message did not dissapear!!
    What can i do.
  • JustManuals
    • Jan 2006
    • 9838
    Re: C920 - how to remove the 80 fuser life warning message
    Paul@justmanuals.com
    • Dijan
      • Jan 2012
      • 16
      use 2-6 at startup! (V and arrow to the right)
      Restet maintenance
      • lavoiejr
        Restet maintenance
        use 2-6 at startup
        • Silvertoast
          • Feb 2010
          • 270
          power off copier. hold down 2 and 6 and and turn power on (keep holding the 2 and 6) depending on your model it might be the down arrow and the right arrow you need to hold down)
          • Dijan
            • Jan 2012
            • 16
            To enter the configuration menu, POR the printer holdingdown the V key and the RIGHTUP and
            DOWN keys, and then pressing the key to select the item.
            • lavoiejr
              To enter the configuration menu, POR the printer holdingdown the V key and the RIGHT key until the operator
              panel displays “Performing Self Test”. The configuration menu can be navigated by pressing the UP and
              Thanks for the answer.
              I knew this configuration Menu and nothing about FUSER COUNTER RESET.
              In the Service Manual Lexmark C920 page 78LX-5056-C920-Manual page 78_Page_078.jpg
              It's said reset the printer internal counter for
              I reset the main counter in the CONFIGURATION MENU .
              This is the only counter in the CONFIGURATION MENU .
              • lavoiejr
                I have accessed a new menu WITH 2 AND 6
                1. ALIGMENT MENU
                  • AUTO ALIGN TEST
                  • CYAN
                  • YELLOW
                  • MAGENTA
                2. PRINT TEST
                3. HARDWARE TEST
                4. EVENT LOG
                5. DEVELOPMENT MENU
                  • BOOT DEVICE
                  • AUTO NOTIFY
                  • DEBUG CONTROL
                  • DEBUG PORT
                  • PRINT HISTORY
                6. DEFAULT
                  • US
                  • NON US
                7. LIGHT QUANTITY
                8. PAGE COUNT
                  • PRT COLOR PG COUNT
                  • PRT MONO PG COUNT
                  • PERM PAGE COUNT
                9. SERIAL NUMBER
                10. MODEL NUMBER
                11. CONFIGURATION ID
                12. RESET COLOR CAL
                Nothing help me in this menu, I have tried and browsed throughout the menu.
                Thanks for this new menu!!!
                • lavoiejr
                  Originally posted by lavoiejr
                  thanks for the answer.
                  I knew this configuration menu and nothing about fuser counter reset.
                  In the service manual lexmark c920 page 78[ATTACH=CONFIG]22447[/ATTACH]
                  it's said reset the printer internal counter for
                  i reset the main counter in the configuration menu .
                  This is the only counter in the configuration menu .
                  configuration menu
                  1. maint cnt value
                  2. reset maint cnt
                  3. black only mode
                    • on
                    • off
                  4. prt quality pgs
                  5. color trapping
                  6. panel menu
                    • disable
                    • enable
                  7. ppds emulation
                    • deactivate
                    • activate
                  8. demo mode
                  9. factory default
                    • restor base
                    • restor network
                  10. energy consum
                    • on
                    • off
                  11. event log
                  12. auto align adj
                  13. auto color adj
                  14. paper prompts
                    • auto
                  15. env prompts
                    • auto
                  16. font sharpening
                  17. standby disabled
                  18. exit configuration
                  • submairner
                    the fuser as well as the transfer belt have fuseable links in them. if you are using a new fuser from Lexmark contact tech support for replacement if its a refurbished fuser odds are that the link wasn't replaced durning build up.
