Lexmark X658de, fuser error
  • copyman
    Owner / Technician
    • Sep 2005
    • 4718
    I posted about this before having an intermittent fuser error
    code, 924.01. Manual states it is a
    thermistor.Someone suggested to replace the fuser
    even though it only has 30k clicks on machine. I
    went ahead and replaced the fuser. Still have error
    code. I suspect pwr supply or controller? Anyone
    have to replace either of these boards? Or any
    other suggestions greatly appreciated.
    Thanks in advance
  • WesTek
    Re: Lexmark X658de, fuser error
    Thanks in advance
    Go LVPS if you have already replaced the fuser. OR you can check the pins on the LVPS to the System board. I just had one where the pins were not properly connecting to the system board, I bent them around a tiny bit and the fuser error was gone. Try pins first, replace LVPS second.
