Kyocera 5035 vertical path sensor (switch) actuator
  • Riviera
    • Sep 2016
    • 66
    Looking for part number for the arm(actuator)and spring of the sensor in left hand door on Kyocera 5035. There are two of them , one each above each cassette entrance. Looks like it is for several models. I ordered the holder , thinking it would be included . But it wasn't and I cant find it in parts manual anywhere. Holder number is 2BL06450 and the arm and spring attach to the holder
    thanks
  • nikolai.aleksie
    • Feb 2016
    • 177
    Re: Kyocera 5035 vertical path sensor (switch) actuator
    Kyocera KM-3035, KM-4035, KM-5035 (Service manual, parts list, service bulletins, firmware)
    DepositFiles provides you with a legitimate technical solution, which enables you to upload, store, access and download text, software, scripts, images, sounds, videos, animations and any other materials in form of one or several electronic files.
      • 23007
      You were close. Right below it item #21:
      2BL27410
      Paper Conveying Switch
