I need SERVICE MANUAL SHARP AR-M205
  • keddada
    • May 2025
  • mannu
    Game on
    • Dec 2007
    • 16
    i will sand u give your mail id
    • mannu
    • keddada
      my dear!
      Hi,
      First than you for the caring, & this's my email ted_jani@yahoo.fr.
      best regards.
      • wangchaoguis
        • Sep 2007
        • 32
        Hi,
        mannu.I need SERVICE MANUAL SHARP AR-M205 too.Can you send it to me? my email:wangchao305503@hotmail.com Thanks.
        • johnnyjamjet
          Sharp Arm 205
          Hi i have a manual (pdf)
          Where shoul i send it?
          • mannu
            Game on
            • Dec 2007
            • 16
            find the att 4 sharp manuals
            plz find the att
            • mannu
            • johnnyjamjet
              plz find the att
              Originally posted by mannu
              plz find the att
              Sorry i don't understand
              • mannu
                Game on
                • Dec 2007
                • 16
                Jhon I Mail The Service Manual Oke
                • mannu
                • wangchaoguis
                  • Sep 2007
                  • 32
                  Thanks mannu.
                  • ntbinh_yb
                    I need Sharp AR-M206 service manual document
                    Sharp AR-M206 Error code H4-00. Who can help me?
                    • johnnyjamjet
                      the heat roller didn't reach the required temp in the time allowed, test the heat lamp with sim 5-2 (diag code #,*,c,*) if the lamp works, if could be the thermostat or just a clich. try a reset with sim code 14 first to see what happens.
                      • Kado1
                        thanks.
                        • printerguy
                          Sharp AR-M205
                          Looking for a manual for this machine. Can you send one via e-mail? Dan@RMPR.net.
                          Getting E-7 error and when scanning the lamp sometimes turns off for no reason. Any suggestions?
                          Thanks!
                          • mickspace
                            • May 2008
                            • 22
                            H4-00
                            Cause Thermistor abnormality
                            Heater lamp abnormality
                            Thermostat abnormality
                            Control PWB abnormality
                            Check
                            and
                            remedy
                            Use SIM 5-02 to check the heater lamp blinking
                            operation.
                            When the lamp blinks normally.
                            Check the thermistor and its harness.
                            Check the thermistor input circuit on the control
                            PWB.
                            When the lamp does not light up.
                            Check for disconnection of the heater lamp and
                            the thermostat. Check the interlock switch.
                            Check the power PWB and the lamp control
                            circuit on the MCU PWB.
                            Use SIM 14 to clear the self diagnostic display.
                            Or Install New Fusing unit, easier and cheaper..
                            • mickspace
                              • May 2008
                              • 22
                              Thanks!
                              If you hold the start button it will show the rest of the code. If it is E7-10, do you have a doc feed, if so remove the slit glass and clean the underside, at either end of the slit glass, there should be a little sticker tab, on the top (where the paper passes) this sticker has white on the under side, it is the reference point for the lamp. I will attempt to e mail a manaul..
                              E7 01 Content Duplex model memory error
                              Detail The memory capacity for the duplex model
                              machine is improper. Insufficient memory
                              capacity
                              Cause The memory capacity of the MCU PWB is
                              improper.
                              Check
                              and
                              remedy
                              Use SIM 26-39 to check that the memory
                              capacity is 32MB. If it is not 32MB, replace the
                              MCU PWB with a suitable one.
                              E7-02 Code
                              Content LSU trouble
                              Detail The BD signal from the LSU cannot be
                              detected in a certain cycle. (Always OFF or
                              always ON)
                              Cause LSU connector or LSU harness defect or
                              disconnection
                              Polygon motor rotation abnormality
                              Laser beams are not generated.
                              MCU PWB abnormality.
                              Check
                              and
                              remedy
                              Check connection of the LSU connector.
                              Execute SIM 61-03 to check the LSU
                              operations.
                              Check that the polygon motor rotates normally.
                              Check that the laser emitting diode generates
                              laser beams.
                              Replace the LSU unit.
                              Replace the MCU PWB.
                              -E7-10 Code- Content Shading trouble (Black correction)
                              Detail The CCD black scan level is abnormal when
                              the shading.
                              Cause Improper connection of the CCD unit flat cable
                              CCD unit abnormality
                              Check
                              and
                              remedy
                              Check connection of the CCD unit flat cable.
                              Check the CCD unit."
