Konica Minolta Bizhub 420 Background
  • mearmi
    • Oct 2010
    • 344
    [CQ] Konica Minolta Bizhub 420 Background
    Hi
    Got Bizhub 420, background on the copy/print when do duplex
    Single side copies/prints are fine.
    Replaced Drum Developer and Transfer corona assembly.
    Please advise
    Thanks and Kind Regards,
    Mearmi
  • kingarthur
    • 1168
    Re: Konica Minolta Bizhub 420 Background
    have you played around with the voltages, from memory raising the transfer voltage helped....obviously make a note of all voltages before you start
    • mearmi
      • Oct 2010
      • 344
      Thanks for your reply.
      No I didn't. Shall I increase the voltage? Or any default value?
      thanks
      • mearmi
        • Oct 2010
        • 344
        By increasing the transfer voltage, the problem is gone.
        thanks a lot for your help
        Kind Regards
        Mearmi
