224e dead display.
  • Paul Ridds
    • Jan 2015
    • 9
    224e dead display.
    Have a dead display on 224e.Motors and drives running but no display. Changed power supply and mfpb.Still no luck.Any suggestions greatly appreciated.
    Sent from my SM-N910F using Tapatalk
  • copier tech
    • 8132
    Re: 224e dead display.
    Does the machine print & copy even though you cant see the screen is the start key blue etc?
    It could be a simply failed screen, I would try removing & refitting all the panel connections
    โ€‹
    • Paul Ridds
      • Jan 2015
      • 9
      Screen ok as tried on another machine. No light or display at all.
      • Albonline
        • Sep 2008
        • 1144
        then you are down to the connections on the wiring harness.
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          when the ram is fried you will get no signs of life from the panel.
          did you install new ram with the MFP board ?
          I've had defective mfp boards destroy ram too, 3 brand new sticks 24 hours apart from each other till mfp was replaced, so replacing it was probably the right thing to do.
          • Paul Ridds
            • Jan 2015
            • 9
            Thanks for all your replies guys.Will let you all know the outcome when I get to the bottom of it.
            • Paul Ridds
              • Jan 2015
              • 9
              Update gents.Turned out to be cable between display and the MFPB.Thanks for the feedback,really helpful.
              • copier tech
                • 8132
                Good fix! Was it a loose cable or did you replace it?
                โ€‹
                • Paul Ridds
                  • Jan 2015
                  • 9
                  Had to replace it,obviously a break in the wiring somewhere. Machine has only been in the client 2 months from new.Pesky Japanese /China assembly line.
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    good to know.
                    Now that I think of it, I beleive another tech at my company had this problem too.
                    Must be the same discount cable supplier that was making the DF-701 cis data cables
