c220
  • CrapAimer
    • 296
    c220
    Hi All
    Have a C220 which keeps selecting A5 from top tray, have changed the board,fingers and sensor in the back, Tray seems fine, any help appreciated
    George
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: c220
    Originally posted by CrapAimer
    Hi All
    George
    What about the photo sensors on the black plastic block that is spring loaded and has the side guide shaft slide into?
    I've had the back guide itself bent back so the shaft misses the sensors.
    • acusso1234
      Tecnico
      • Dec 2008
      • 250
      Re: c220
      Sometimes helps regulating the two screws into the slotted holes under the paper contained in the cassette.
      ... In the minute that you're thinking of giving up, think about why you lasted so long ...
      • habik
        • 2013
        Re: c220
        As EarthKM Tech suggested have a closer look on that sesor bracket they tend to crack on the long stepscrew!
        Sent from my iDon't believe in marketing device using Tapatalk
        Firmwares HERE
          • 23007
          Re: c220
          I'm glad to see that you're back, habik. =^..^=
          • Bilal
            Re: c220
            can anyone tell me how can i turn off my finisher as my paper is jamming there and i don't have any use of it though.
            • Woxner
              • Jul 2011
              • 848
              Re: c220
              just unplug the finisher then turn machine back on. agree check metal lever are not bent
                • 23007
                Re: c220
                1) power must be off first
                2) Unplug bridge from finisher, and finisher from back cover.
                3) Remove bridge.
                4) power ON.
                • allan
                  RTFM!!
                  • 5462
                  Re: c220
                  Its one of my boot stock items. Called "Holder" as per description.
                  Whatever
