Anyone know if you can swap the Drum Assembly, complete, and the DV assembly from a 420 to a 7135? They look the same, but are sensors within the same?
the 7145 is similar to the 420, not the 7135.
you can cheat like i do and search consumables on precisionroller.
if the part#s are the same i can cross but from what i see if the pics are accurate they are physically different.
here is a sample Konica Minolta bizhub 420 Drums Konica Minolta 7135 Drums
Another good trick is to download the full Parts Pricing List from Konica, then look up your part number. It's a quick way to get a list of machines that use the same parts, as well as finding updated part numbers ("NLA - Use ____ instead").
Drums on the 7135 vs 7145 are different, the ends of the drums in which the shaft goes thru are different, over the years I have used and cross used the toners/developers for those machines, from the 7020's to the 7145's, no issues. When using the 7020 dv in a 7145, the c/q is rich and very good solids for over 100k.
