283
  • uzicomp
    • Feb 2015
    • 35
    I replaced the drum
    I cleaned the corona
    Changed
    ds roll kit
  • Kapral
    • Oct 2012
    • 43
    Re: 283
    You might have a problem with magnetic roller in developer section.
    • Synthohol
      Certified Konica Expert
      • 5740
      Re: 283
      drum and developer must be replaced together on the 3 series.
      if not it creates a whole range of CQ issues.
        • 22942
        Re: 283
        I'll have to agree with the previous gentlemen. Those look like developer copies to me. Are they gritty? =^..^=
        • allan
          RTFM!!
          • 5459
          Re: 283
          Do you have a hole in the inner dev seal?
          Looks like arcing to me.
          I am confused about the feed direction.
          If it is in the feed direction its the mag roller. Wipe off the developer, if it is shiny that is your problem replace the dev tank.
          Whatever
          • uzicomp
            • Feb 2015
            • 35
            Re: 283
            ty
            i will check the tank developer
            and l"ll tell
            • Woxner
              • Jul 2011
              • 829
              Re: 283
              you must aslo reset the counter when replacing parts. after doing dev you must also run the tcr adjuustment
              • uzicomp
                • Feb 2015
                • 35
                Re: 283
                I replaced the tank developer it works great
                and I reset the counter
                ty
                  • 22942
                  Re: 283
                  Congratulations on your success. =^..^=
