Now will not print one piece of paper from tray 1. The paper jams as it starts to exit from the fuser.Changed the loop adjustment,new firmware.Jam code now 99-01 controller jam.Tray 2 and bypass still working.No other messages about paper size.at a loss.
bIZHUB 423 TRAY 1
Re: bIZHUB 423 TRAY 1
Was tray 1 feed unit replaced from another model?
The 423 has an extra sensor that the slower models don't and can give the symptom you describe.We know a thing or two because we've seen a thing or two.
The medication helps though...Comment
The extra sensor in the 423 is for paper length and without it the paper is seen as a different size and asks to load paper size correctly.
Good luck, let us know!!We know a thing or two because we've seen a thing or two.
Have seen more than a few 363 and 423 do this because the drive motor slowed down, try trading the two on the back around.Comment
