liondor1969 liondor1969 liondor1969
  • Synthohol
    Certified Konica Expert
    • 5739
    dont use the word print in the title of your thread, this BBS is broken and for some stupid reason the word print makes your thread read only in print view. nobody can answer you.
    BTW your issue is with magenta. make sure the laser path is clean and the mag roller on the magenta developer has a good brush to it.
  • liondor1969
    • Jun 2016
    • 72
    Re: liondor1969 liondor1969 liondor1969
    for this line i must check laser path (i must find where is this )IMAG0227.jpgIMAG0228.jpg
    after I dismounted i found this problem..IMAG0246.jpgIMAG0242.jpg what to do please ?IMAG0244.jpg
    thanks for your help...
    • Synthohol
      • 5739
      yes, the magenta is dropping off.
      print a halftone of magenta to verify.
      • liondor1969
        • Jun 2016
        • 72
        :-(is posible to repare this or i must change all unit..half tone printing is on service mode test 53 ? i am a novice in this joob.. hiere wer i live take 1-2 week too visit my a service man from minolta,i must print 4000 prints in 2 days..
        thanks for yor replay..I appreciate,please tell my this cylinder is broken ? was scratched lessIMAG0226.jpg o or it can be used ?
        • Synthohol
          • 5739
          looks like A4/letter/A3/ledger may miss the scratch but it looks like anything wider will show the defect.
          either way the drum should be replaced.
          the scratch is not causing the line you have a magenta problem.
          • liondor1969
            • Jun 2016
            • 72
            HAW TO PRINT service mode test 53 on KM 6500... ? tx
              • 22942
              The magenta problem is some sort of foreign matter under the doctor blade, and can be easily solved. Make yourself one of these from heavy mylar:
              Start the hooked end of the tool under the doctor blade and slide it across until you are aligned with the void in your brush. Rotate the mag roller while pulling out the tool. Watch for the obstruction so that you can snag it before it feeds back into the developing unit. Repeat as necessary.
              The drum cannot be saved. Order a new one. =^..^=
              • liondor1969
                • Jun 2016
                • 72
                [ATTACH=CONFIG]35553[/ATTACH]
                Hallo..
                i prepare toolsIMAG0247.jpg have 2cm/12cm,hiere is my problemIMAG0248.jpgIMAG0249.jpg..I not really understand how to do this job..to introduce the hook in the bottom or the top..thax for all your help..i must resolve this
                THAKSSSSS blackcat4866 ...i resove this,naw is perfet..thank you
