Konica Minolta bizhub 250
  • Guest
    Customer complains that machine freezes. All powered up in Ready but no response when selecting anything! Has to turn off power and un-plug. Then it works again for a little while then freezes again
  • Woxner
    • Jul 2011
    • 829
    Re: Konica Minolta bizhub 250
    is it just the screen freezes or can you still print? if its the screen try recalibrating the touch screen. if its the screen may need the touch glass under neath.
    • spree
      • Jun 2012
      • 211
      When you can print and you can not touch any function on touch screen - you must change touch screen. When you can not print, I think it is a formatter board.
        • 22937
        Are there any error recorded on the management list? =^..^=
        • Guest
          Replaced touch screen Can not print. Which is formatter board. What about firmware/
          • Guest
            Touch screen was replaced but the print button does not respond either. Someone mentioned formatter board? haven't checked mal function history (no codes). What about firmware?
            • Nommo
              • Apr 2014
              • 27
              It's kind of outdated, but it may be RAM failure. On the newer series that was the issue - screen shows image, but is not touchable nor you can print.
