C3110 Rebooting
  • B0265
    • Jan 2007
    • 718
    C3110 Rebooting
    We have 3 x Bizhub C3110 at the same customer and all of them can randomly (?) reboot. This can happen booth in stand-by and during a print job.
    Have anyone seen this problem?
  • mo0651
    • 1054
    Re: C3110 Rebooting
    Yep!! what have you done so far?
    • B0265
      • Jan 2007
      • 718
      Re: C3110 Rebooting
      Updated Fw and ordered a new Power supply (not delivered yet).
      • mo0651
        • 1054
        Re: C3110 Rebooting
        Did you check ERP mode and low power settings??
        • B0265
          • Jan 2007
          • 718
          Re: C3110 Rebooting
          I don't think that the power save settings is the cause when the printer reboots in the middle of a print job.
          • mo0651
            • 1054
            Re: C3110 Rebooting
            I wouldn't think you would have three bad power supplies. Sounds more like a configuration issue. Firmware fixed my issues. Just some ideas.
              • 22941
              Re: C3110 Rebooting
              Have you checked the error code list? =^..^=
              • Woxner
                • Jul 2011
                • 829
                Re: C3110 Rebooting
                duplicate IP or corupt job will cause these to reboot as well.
                • allan
                  RTFM!!
                  • 5459
                  Re: C3110 Rebooting
                  In this case a will install a loan and take one back with me and have the admin department use it for a day or two to see if it miss behaves.
                  Also put a power logger on one. Have seen C35 reboot if the fuser needs to heat up, there was a bad breaker in the DB.
                  Take one off of the network and see what that does.
                  Or put a mini switch between the network and the machine don't know why that works, in some cases but it does.
                  Whatever
                  • B0265
                    • Jan 2007
                    • 718
                    Re: C3110 Rebooting
                    I agree on that. The tech that was onsite ordered the Power supply to eliminate that as a cause.
                    What FW version did fix your Machines?
                    • B0265
                      • Jan 2007
                      • 718
                      Re: C3110 Rebooting
                      I have checked the error code list for two of the machines, the only thing that is listed is "uncategorizable" 1 time in on of them.
