OPC drum has scraches and i must replace it. Do i have to replace developer too? if i replace only drum and blade and not developer do i have any problem?
biz 501
Re: biz 501
If the print quality is ok (except for the drum scratches) and if the developer isn't over life, then, if I remember correctly, there should be no reason to replace the developer.
Anyway it would be wise to take a developer bag with you just in case.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation! -
Re: biz 501
if the DV life is under 60% you may get away with it.
just do your LD1s and LD@ adjustments. and reset the drum and blade counters.
i usually set them so the first shading blocks just shows up just over the line. saves for overtoning and the mess it becomes.We know a thing or two because we've seen a thing or two.
The medication helps though...Comment
