konica minolta c3110 with an fbob code
  • brent
    • Nov 2008
    • 1212
    weird code. but the manual said it was an abort code this machine has been problematic
    from the beginning.. when it had any code on it. we had to unplug it let it sit and it would come back
    on usually with no lights on the display any thoughts on this or the fbob code?
    thanks guys very much
    brent
  • tech51
    • 846
    Re: konica minolta c3110 with an fbob code
    Update the firmware to the latest. That should cure it.
      • 23008
      Firmware is at release 1 controller (A6DT30G0116-999) and scan (A6DT23G0101-999), or release 2 controller (A6DT30G0204-999) and scan (A6DT23G0101-999).
      The bug is fixed in firmware to release 3 controller (A6DT30G0304-999) and scan (A6DT23G0300). Firmware is currently at release version 8, sub controller (A6DT30G0803-899), main controller (A6DT30G0C02-999), engine (A6DT0Y00050G001200_A), and scan (A6DT23G0402-999).
      If you've never done firmware on a bizhub C3100, It's a little different than the majority of bizhubs, and different from the Lexmark based printers. It does some unexpected things. I recommend that you read the README file that I put together before you do it. And please don't ask for the firmware. =^..^=
      • B0265
        • Jan 2007
        • 718
        I've had this once. I tried the setting below but that only changed the indication from an error code to a jam. The solution for us was to change the ADF unit.
        SoftSW No.291
        = 0: Indicate FB0B as before.(Default)
        = 32: JAM is indicated instead of FB0B
        • copier tech
          • 8144
          Thanks for the word doc very hady to read while waiting!
          Out of interest does it matter what order I update the files? I have just done them in the order saved to usb.
            • 23008
            It's most important during the transition from a single controller file to the main controller and sub controller files.
            • jwai
              • May 2018
              • 508
              I have one machine with version 8 F/W, it displayed this code and reset it with power off/on main switch.
