C284 e
  • jonpaul
    • Jul 2014
    • 59
    C284 e
    We have a C284e that when switched on begins warming up screen starts up then after 30 seconds switches off then restarts and so on tried firmware no go .
  • Synthohol
    Certified Konica Expert
    • 5740
    Re: C284 e
    likely bad SSD board.
    • jonpaul
      • Jul 2014
      • 59
      Re: C284 e
      thank you it bwas the ssd board, I don t suppose you know the part no for it.It s not listed on our KM parts list.
      • Optimus Prime
        • Aug 2012
        • 6
        Re: C284 e
        Hi,
        It was something Konica exchanged for you by sending the old one back. Then it was new firmware that seemed to cure the problems.
        Regards
        • Elmo
          • Feb 2010
          • 541
          Re: C284 e
          Konica did issue a bulletin and a part number for the SSD
          i will see if i can find it
          I Used To Live To Fix Things Now i Fix Things To Live
          • Synthohol
            • 5740
            Re: C284 e
            SSD boards are not orderable part there is a special program through Konica website to order it you have to be an active dealer in order to get it through normal channels
            • copier tech
              • 8106
              Re: C284 e
              This is the p/n a cheap item to order.
              9960P00H02D14P - SSD
              • avecosat
                • Jun 2012
                • 303
                Re: C284 e
                Are you sure ??? Is a MDS-assy
                • copier tech
                  • 8106
                  Re: C284 e
                  • avecosat
                    • Jun 2012
                    • 303
                    Re: C284 e
                    Thanks , Do you know the reference for 8series SSD ?
                    • tech51
                      • 846
                      Re: C284 e
                      There is no number for the 8 series emmc board. We still have to go through a return process for them at present, even direct service have to.
                      The 284e series ssd boards were eventually released as a part, I guess as a result of the high number of failures/downtime they caused.
                      Although I have had to replace a couple of 8 series emmc boards, they are nowhere near as bad.
                      Also I would check that number as it might just be UK or Europe only.
                      Best of luck......
                      • lazymangr
                        • Feb 2017
                        • 115
                        Re: C284 e
                        why dont replace with a generic ssd with same storage capacity? been using retail hard drives for replacement on all other versions. format them and ready to go. the thing that they ship the hdds with special firmware in it is bullshit.
                        • Synthohol
                          • 5740
                          Re: C284 e
                          lol, the SSD is not a HDD, its an EEPROM.
                          • lazymangr
                            • Feb 2017
                            • 115
                            Re: C284 e
                            i know what ssd is. but both hdd and ssd are storage. nothing diferent in the usage.
                            • Synthohol
                              • 5740
                              Re: C284 e
                              Seriously?
                              Ok, if you say so. (Shrugs and walks away slowly backwards)
