Bizhub C554e PRCB Swap (used)
Re: Bizhub C554e PRCB Swap (used)
The last time I had a problem with a PC410 it was the small pcb above the other boards, A5AYH00501 PWB Assembly(PWB-EX), it's very easy to pull the connector out, especially if you're swinging the other boards out to the right.Tip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away... -
I had a C454e which had misfeed problems, coming from the PC -410, it was actually that PCB, but thinking back, it was also misfeeding from tray 2, so it probably won't solve your problem...Tip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...Comment
Yeah this one only has a problem with the PC-410. It knows its there but will never even try to feed or lift.Comment
Yes you can change one board at a time from a donor machine. SSD is a board too!.
Take from B(donor) and install in A to test if not the problem take from A and reinstall in B and Boot it up otherwise you brick your donor machine.
Then there is the reset tool that claims to recover mismatched boards. But in my opinion if you won the fight stop wrestling.
Some where KM describes the procedure for "test" only.
Got machines that is running with donor boards for some time now.WhateverComment
There is a specific procedure if you want to fit a used or new PRCB (see attached)
Precedures and Guidelines for replacing MFP and PRCB.pdfLet us eat, drink, and be merry, because tomorrow we may die!
Sorry did not mention firmware as that should go without saying.
Did this with not much trouble without reading a thing.
WhateverComment
