Hello Everyone,
i have a Bizhub 4000P Printer and have 3 questions:
1. My printer is from 2014 and has the first firmware on it (LW32.PR2.P331 / FDN.PIR.E412).
I want to upgrade to a new version. Can someone help me out with an up-to-date firmware?
2. I tried to upgrade the printer memory and inserted a 1GB DDR3 RAM DIMM into the memory expansion slot on the controller board.
When i turn on the printer it gives me a "959.20 Service System Board" error. Without the memory installed everything is working fine.
But with installed memory the Printer won`t start. Why is that? Do i have to get some kind of proprietary Konica Minolta memory or do i have to get a license for the memory upgrade?
3. The 4000P should support Apple AirPrint. When i check my license file in the web interface it states "Printer.AirPrint 1" but none of my Apple devices can find the 4000P.
There is no option in the web interface or the printer settings to enable it. Other Printers are working just fine. Do i just need a newer firmware? Or why is this not working?
It would be great if someone could help me out here
Thank you very much!
