Bizhub C353 giving streaky prints
  • mckenna
    • May 2025
    What is wrong?????? Please help!!
    It seems to do fine with 20lb paper but this is 110 lb card stock. I have done hundreds of these prints with no problems and all of a sudden this is all I can get with the heavier paper
  • orestesp
    • Sep 2019
    • 221
    Re: Bizhub C353 giving streaky prints
    It looks like the toner isn't getting fused to the paper properly.
    Have you set the tray to the correct paper setting?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4542
      Yep. Looks like you don't have the tray set to thick paper. You should run thick paper from side tray ONLY set to thick 3 or 4 paper. If the paper is really glossy it will not work with this model.
      • qbert69
        • Mar 2013
        • 1152
        Originally posted by mckenna
        [ATTACH=CONFIG]44864[/ATTACH]
        There is *some* fuser offset there, but it ALSO looks like it could be the Intermediate image transfer belt cleaning blade going bad as ALL COLORS are being affected!!![emoji41]
        PS--The "Repetitive Defect" distance is too great which indicates that it IS NOT the fuser rollers...most likely the ITB!
        Sent from my SM-N950U1 using Tapatalk
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
          • 22942
          Yes, there's a high voltage loss going on here. It could be any one of the imaging units. =^..^=
          • mearmi
            • Oct 2010
            • 346
            Please check all the imaging units. Remove and check one by one, all are rotating normally and ITB.
