You won't believe it.......
  • Hansoon
    • Sep 2007
    • 3350
    Bizhub 350, yes the old dinosaur. Have still a few of these machines with coin-op. One of them got a new PWBA and since than the "Vendor Mode" disappeared (TechRep>Stop9>MeterCount) All possible entries for the counters are shown but not the "Vendor Mode" which is missing.
    Machine has ofcourse the "Latest&Greatest" Firmware.
    Any ideas please?
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
  • Synthohol
    Certified Konica Expert
    • 5740
    Re: You won't believe it.......
    is there a HDD? is it on?
    • Hansoon
      • Sep 2007
      • 3350
      Nope
      Hans
      • emujo2
        • Mar 2017
        • 1580
        This may be a firmware issue...
        Older Firmware
        1. On the basic screen, hit the “utility/counter” button.
        2. Touch “Check Details” on the touch panel.
        3. Press “Stop”, “0”, “0”, “Stop”, “0”, “1” to enter Tech Rep mode.
        4. A password is required. Key in 00000000 or 12345678 and press “End”.
        5. Once in Tech Rep mode, Press “Stop”, “9”.
        6. Touch “Key counter” and change the setting to “Yes”/”Set”/”ON” (depending on firmware version) and press “End”.
        7. Touch “Vender mode” and choose “Coin” from the selections. Touch “End”
        8. Press “Auto Reset” to get out of the current menu.
        9. Press “End” to get out of Tech Rep mode.
        10. Once back on the basic screen “Insert coin” should be displayed if done correctly.
        Newer Firmware
        5. Once in Tech Rep mode, Press “Stop”, “9” to access Count mode.
        6. Touch “Management Function Choice”.
        7. Choose “Vender 1”. Verify if “type 1” is selected and touch “End”.
        8. Press “Reset” to get out from the current menu.
        9. Exit completely from tech rep mode.
        10. Once back on the basic screen “Insert Coin” should be displayed if done correctly
        Also, vendor mode is not available if account track/user authentication is enabled..Used PWB might have something to do with this. E
        • copyman
          Owner / Technician
          • Sep 2005
          • 4542
          Been awhile since i worked on that model but can you initialize the machine like newer models? My thinking is wipe all the settings and start fresh.
          Maybe a softswitch setting?
          • tsbservice
            Field tech
            • 7924
            Maybe an idea to do memory clear via Jumper across TP1 and TP2.
            • Hansoon
              • Sep 2007
              • 3350
              Machine is working again but it needed another PWB-A.
              Thanks for your support gentlemen.
              Hans
