Which rolls do you prefer to use?
  • Bix
    • Apr 2018
    • 1421
    Konica Minolta has evolved in the type of rollers used in the trayers. Which one do you prefer to use? Do you use original or third-party rollers?
    I currently use those with the included C-Clip:
    A64J564201
    A64J564101
    Its are valid but C-clip break easily if you are not careful.
  • rrrohan
    • Sep 2011
    • 1977
    Re: Which rolls do you prefer to use?
    Does it matter if you replace blue rollers with red ones. I only bother stocking the A00J563600 and pull the rubber off to use the original shaft so use A00J rubber on a A108 SEP roller shaft.
    I was told like 10 years ago blues lasted longer but haven't really noticed much difference
    Sent from my Nokia 7 plus using Tapatalk
    • escalante
      • Sep 2018
      • 115
      In which model do you use these rollers?
      Enviado desde mi SM-J701M mediante Tapatalk
      • Bix
        • Apr 2018
        • 1421
        in all models (the rollers are almost all the same). I speak more specifically of the A3 models
        • Synthohol
          Certified Konica Expert
          • 5804
          i use A00J563600 rubbers for everything.
          ive also got the c clips so if i break a lock tang then i just make it like a 4 series
          • BR549
            • 109
            We use OEM rollers. We had lots of problems with Katun rollers about 10-15 years ago. We were replacing clutches, 1 way bearings, torque limiters and sensors before we figured out it was the Katun feed rollers. I think we may have even lost a few customers because of it. Trying to save money with generic parts and supplies will sometimes end up costing you more. Instead of ordering A00J563600, order A0P0R74000. Last time I checked, it was less $. It is the same roller, plus it includes a shaft, torque limiter and clip that you can sometimes use for the sep roller. Sometimes the shaft is different but torque limiter is the same so just use the old shaft.
            • Synthohol
              • 5804
              i even use the A00j's on Kyoceras. seem to last longer
              • escalante
                • Sep 2018
                • 115
                A64J564201
                A64J564101
                And duration has these rollers. Why the part codes are from series 8
                • Bix
                  • Apr 2018
                  • 1421
                  my experience, 200k-400k
                  • qbert69
                    • Mar 2013
                    • 1152
                    Good to know!!! ...we have a few kyocera in the field but are slowly swapping them out for 4e series KMBS boxes!!! Kyocera touts long life for their amorphous silicon drums but the charge rollers don't hold up worth a crap! You're lucky to get 100-120 k out of a single charge roller!!![emoji15]
                    Sent from my SM-N950U1 using Tapatalk
                    REACH FOR THE STARS!!!
                    Konica Minolta Planetariums!
                    • Synthohol
                      • 5804
                      the KM color 8 series also has the charge foam curse.
                      • patrickjlc
                        • Feb 2015
                        • 223
                        I use the red jelly ones, original from Konica. Compated to Kyoxera whete i wpuld be changing rollers every 30k this KM have been good for so far 100k
                        Sent from my SM-G930V using Tapatalk
                        • Bix
                          • Apr 2018
                          • 1421
                          What is charge foam?
                          • tsbservice
                            Field tech
                            • 7977
                            I guess Synthohol means drum charge roller instead of corona like 4/4e series and older. It's not exactly foam though more like rubber coating...but sure charging roller cleaning roller has foam
                            • EarthKmTech
                              Step aside, noob
                              • May 2009
                              • 2139
                              I am fitting the pink A64 clippy rollers to everything that can take them as I dont want to carry a million different roller types.
                              Unfortunately my OCD doesnt allow me to fit them to the 958 series with their integrated white double clip so I still have to carry the old A00J red and A5C tracktor wheel, but in smaller quantities than I used to.
                              The pink A64 rollers actually turn red when you swap them onto the black core and the red a00j rollers turn pink when swapped onto the grey core so I beleive the roller material is actually the same.
