Bizhub c224 - scanner issue
Re: Bizhub c224 - scanner issue
Invalid Attachment specified.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused. -
Now we can see.
Scanner bed front left area is pushed down. You have to try "gently" tug it upward.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
Loosen the screws on both hinges and adjust the RHS adjuster screw until the copy is straight. Check the height (gap) is even all the way around the DF. Finally calibrate using a test chart.(every new copier will have a DF calibration chart) if you don't have it just stick to manual adjustment. There is also adjustment for pressure rollers in the DF cover that move white rollers up and down. Give them a go. Make sure all relay rollers are clean and exit mylar is not worn and without any ripped ends.Comment
Loosen the screws on both hinges and adjust the RHS adjuster screw until the copy is straight. Check the height (gap) is even all the way around the DF. Finally calibrate using a test chart.(every new copier will have a DF calibration chart) if you don't have it just stick to manual adjustment. There is also adjustment for pressure rollers in the DF cover that move white rollers up and down. Give them a go. Make sure all relay rollers are clean and exit mylar is not worn and without any ripped ends.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
I know it's a bit confusing getting such a wide variety of advice.
I'm with tsbservice. The scanner frame gets bent from endusers leaning on it. As a starting point I usually use a tape measure. Remove the scanner outer covers, and measure the distance from the floor to the top of the scanner frame at both the front and the back. I've seen a difference of up to 10mm in those measurements. Clearly this won't work on carpeting or an uneven floor. Then loosen the screws that secure the scanner, and pull it back up to the point where the measurements are the same. Then tighten the screws.
One of our in shop techs used an automotive scissors jack to push the scanner up slightly past level, then screw it down tight. I'd imagine that would be hard to explain to a curious customer.
Back in the analog days the Ricoh monochrome machines were known for this. We called it "The Ricoh Bear Hug". I'd take a look around to make sure the enduser wasn't watching, then I'd lean over the scanner slipping my left arm under the scanner and gently lift the machine off the floor a few times.
Don't even think about the electronic adjustments until you've done this part. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Don't even think about the electronic adjustments until you've done this part. =^..^=Adversity temporarily visits a strong man but stays with the weak for a lifetime.Comment
What do you suggest? =^..^=If you'd like a serious answer to your request:
I don't know. I'm not looking at the machine. I was just thinking it may be better if you could find a reference point on the machine that would eliminate things like carpet or an unlevel floor.
With that said, I give you a lot of credit. Most folks wouldn't even think to do what you did.Adversity temporarily visits a strong man but stays with the weak for a lifetime.Comment
May have a database with measurements from different models in good working conditions. For example measure distance front and rear side(fixed points on scanner bottom) to some reference points below that are same in all C224e ie. So when have to deal with this problem you know your references and compare with existing distances. Anyway as usual BC methods are unexceptionableA tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
