aloud
  • zezo aloud
    • Feb 2021
    • 7
    aloud
    Hello.. the adf is outputting multiple sheets of paper together while copying bizhub 364e..
    I changed the upper and lower pulleys but no change... Please what is the solution.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4537
    Re: aloud
    Did you replace the rollers? Especially the separation roller? Clean or replace paper feed clutch?
    Also check switches on top door of ADF
      • 22939
      Re: aloud
      It's very easy to get the separation spring misaligned, there's a bottom post for it to rest upon ... which lets multiple originals feed. I've done it to myself a couple of times. =^..^=
      • zezo aloud
        • Feb 2021
        • 7
        Re: aloud
        Yes, I changed all the pulleys, but I didn't know what the feed clutch you mean? If you have a picture of him I would be grateful to you brother.
        • zezo aloud
          • Feb 2021
          • 7
          Re: aloud
          Where is the spring or clutch in the picture?
          • tulintron
            • Jul 2014
            • 669
            Re: aloud
            Originally posted by zezo aloud
            [ATTACH=CONFIG]52892[/ATTACH][ATTACH=CONFIG]52893[/ATTACH]
            It's below the separation rollerBlack Cat 4866 Merits
              • 22939
              Re: aloud
              After you remove the separation roller you can see the spring ... underneath. =^..^=
              • zezo aloud
                • Feb 2021
                • 7
                Re: aloud
                I changed the pulley, but returned the old spring. I will change the spring and hope that is the cause of the problem.
                • mascan42
                  • Oct 2008
                  • 480
                  Re: aloud
                  On rare occasions, I've actually had to cut a couple of turns off that spring to get the proper pressure. But make sure you have a spare with you in case you overdo it.
                    • 22939
                    Re: aloud
                    I find it in interesting that you persist in misunderstanding my statements. There usually is nothing wrong with the spring, it is just installed incorrectly ... not onto the lower post. But if it helps you install the spring correctly, then please, order another one. =^..^=
                    • zezo aloud
                      • Feb 2021
                      • 7
                      Re: aloud
                      Sorry if I bothered you.. but I think the spring is in place as in the picture, so I thought the problem might be with the spring being weak. Thanks for your info anyway.277831160_375726717809052_8381350039924948162_n.jpg
                      • Gift
                        • Mar 2011
                        • 2447
                        Re: aloud
                        Hard to judge from the image but the sep roller appears a little "wasted" to me and the spring like as if somebody has tempered with it.
                          • 22939
                          Re: aloud
                          The spring is in place correctly. I agree that that separation roller looks extremely worn smooth. =^..^=
