Brother HL 2030
  • vaclav borc
    • Jan 2008
    • 75
    Brother HL 2030
    Too light prints.
    I cand find result with this problem - too light prints.
    I did this procedures:
    cleaning laser+mirrors
    inspected all high voltage contacts
    new toner
    drum reached only 50 percent
    cleaned corona wire, grid, repaired all contacts
    please any ideas?
  • xcopytech
    • Aug 2006
    • 1794
    did you tried with new drum?
    maybe someone reset drum counter earlier.
    • E Winter
      Wow, you've put a lot of energy in this little, cheap device^^
      Are the drum and toner OEM?
      You can try to reset the toner bias - you'll need fiddle something at the toner cartiridge backwards so it does hit a switch inside the printer. You should also check if there is a possibilty to enable a toner save mode within the printer driver.
      • imaginGuru
        Have you checked if this machine has the toner save mode activated?
        Happened to me once, all I needed to do was to clear that mode out.
        • E Winter
          great minds think alike^^
            • 23003
            One last thought.
            I had a series of OEM cartridges (new-in the box) that were missing the small white buttons & springs that press the toner cartridge up to the drum. Cartridge #1 was missing the left button & spring. Cartridge #2 was missing the right button & spring.
            This one was a strange one to diagnose. New cartridge #1 is light at the left. Change cartridge to #2, now light at the right.
