Biz 361
  • Gab
    • Aug 2015
    • 657
    Biz 361
    When toner ended i tried to replace the toner bottle with a new one but the old toner stucked!
    I removed toner hopper and removed the old toner bottle. But when i tried to put the new toner there where some resistance to place it and the TONER CARTRIDGE PRESSING ASSY closed with difficulty and machine doesn't accepted new toner.
    Both toners were compatible.
    • 22942
    Re: Biz 361
    When that bottle rotater is working properly, there is an alignment slot which lines up at the top of the rotation with a feature on the bottle. If the rotation sensor is dirty, it won't necessarily stop rotating at the top of the rotation, to properly align with the feature on the bottle. If the bottle is accidentally of purposely misaligned, then forced in ... it's nearly impossible to remove ... especially when the toner bottle is new/full.
    If you have a later production machine there may be an access port in the metal cover over the toner bottle, to clean the rotater sensor. If you have an early production machine, it's a major operation to get to that rotater sensor to clean or replace it.
    I don't miss these machines very much. =^..^=
    • copyman
      Owner / Technician
      • Sep 2005
      • 4540
      Re: Biz 361
      This "1" series had known issues with toner bottle ring, etc as the Cat posted. I still have a customer with a Biz 421. If not mistaken these were like a hybrid, half analog, half digital. Or they seem like it anyway. Reminds me of a glorified Biz 200 !!!
      Precision roller still sells parts for these, although most out of stock and have to be ordered.
        • 14406
        Re: Biz 361
        These POS machines used a crappy legacy Konica engine and a Minolta scanner and DF.
        • Gab
          • Aug 2015
          • 657
          Re: Biz 361
          The problem is that it doesn't close when turning TONER CARTRIDGE PRESSING ASSY . I think it meaNS THAT toner bottle has to go forther inside the machine.
            • 14406
            Re: Biz 361
            There is a ring at the back of the hopper that has a notch. If that notch gets out of sync, the bottle won't insert all the way.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4540
              Re: Biz 361
              Exactly. That's what I meant by hybrid. Not half analog / half digital. It is a digital box all the way just konica crap!
              • emujo2
                • Mar 2017
                • 1580
                Re: Biz 361
                You need a hammer, and if that doesn't work, a bigger hammer..LOL
