KM bizhub 283 - manual paper feed problems
  • spree
    • Jun 2012
    • 211
    Konica Minolta bizhub 283: the papers are added to manual paper feed tray - O.K., than you want to print and the tray goes upwards, than in a moment down, but the pick-up roller is not turning. The pick-up roller become to start turning after the tray goes upwards, than down - and this make error.
    Do you have this case?
    I can change whole manual paper feed (bypass tray assy):
    A1UDR70600 - Bypass Tray Assy
    or it will be enough to change this parts:
    A108M50100 - Photointerrupter
    9J06M20000 - SOLENOID
    A1UDM20100 - Clutch
    A02E595100 - Clutch assy
    Thank you.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4542
    Re: KM bizhub 283 - manual paper feed problems
    It's most likely the clutch but if you change all those parts or the complete manual feed tray issue should be solved.
    Of course first make sure pick up roller is good
    • Synthohol
      Certified Konica Expert
      • 5740
      what was the error code?
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        bypass trays that lift, drop then error with a lift code on old machines is almost always the lift plate clutch solenoid - the pad goes sticky and the arm cannot release fast enough and allows the clutch to make a full rotation instead of half.
        It must be replaced with similarly thin material. Metal on metal is also unacceptable as residual magnetism will also delay the release. Even adhesive mylar is fine.
        • femaster
          • May 2011
          • 1466
          I'll second this. I've repaired many of this series of machine with this problem. The noise damping foam gets sticky because of age and the metal plate doesn't release fast enough.
          • L0rdC
            • Feb 2021
            • 82
            this one!
            • spree
              • Jun 2012
              • 211
              OK, I ordered whole manual paper feed (bypass tray assy):
              Thank you for your help.
              • Hansoon
                • Sep 2007
                • 3350
                Good Lord, what a waste of money for only curing a sticky pad.......
                Hans
                “ Sent from my Intel 80286 using MS-DOS 2.0
                https://www.copytechnet.com/images/smilies/biggrin.png
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4542
                  Hans
                  Agree! I've seen new parts & accessories really cheap for this old model but would still fix it.
                  • allan
                    RTFM!!
                    • 5459
                    Why even bother to create the thread. Wow yea.
                    Whatever
                    • spree
                      • Jun 2012
                      • 211
                      Hans
                      You are right I waste money (but the customer pay it). It is for "just in case". Maybe my bad decision...
