C3070 Fusing Swing Unit
  • nikkons
    • Jun 2016
    • 6
    [Misc] C3070 Fusing Swing Unit
    Good evening, has anyone ever changed the fuser swing unit or try to fix some parts on it ? there is no procedure to do this ...
    • 23007
    Re: C3070 Fusing Swing Unit
    According to the manual there are factory adjustments to the fuser swing unit that cannot be duplicated in the field. Why do you need to change it?
    • nikkons
      • Jun 2016
      • 6
      Thanks for your reply ....
      There is a malfunction (C3303) to the fans due to a customer fault ...and it needs to be changed ...
      Best regards
      Nick
        • 23007
        All that I can suggest to you is to carefully scribe & mark each of the slotted adjustments and attempt to reposition the new part in the exact same place. I'm assuming it's the alignment of the fuser in the paper path that's critical, but there may be additional reasons for the adjustments.
        Watch for wrinkling of the paper & paper skew (especially second side).
        I'll be interested in the results. =^..^=
        • Afanasy
          • Aug 2023
          • 25
          Hi, hope, it's help.
          • nikkons
            • Jun 2016
            • 6
            Thank you so much !!!!!!
            • wjurls
              • Feb 2017
              • 496
              This is great! I've never had to tear into the swing section yet (just disable if needed) but it always seemed like a daunting task.
              Like the OP mentioned, there is no procedure in SM for it.
              • colorguy
                • Jan 2011
                • 3
                Thank you for this, I had one of those fans go bad on a C2070.
                This is great, I could not figure out where that last screw on the back was.
                • aussieducker
                  • Mar 2010
                  • 8
                  make sure your screwdriver is well magnetized, for screws at rear.
