Transfer belt blades?
  • mrfuser
    • 1617
  • copyman
    Owner / Technician
    • Sep 2005
    • 4692
    Re: Transfer belt blades?
    Originally posted by mrfuser
    Does anyone have a source on the cleaning blades for the transfer belt assemblies on the C364 and “4” series in general?
    Copylite & Katun
    I've used the aftermarket belts & blades to rebuild the transfer units many times and have worked well. The belt & blade is same for the C224 to C554. Also same for "i" & "8" series.
    here is link for copylite: Copylite - Aftermarket, Compatible, and OEM Copier Supplies and Products
    • mrfuser
      • 1617
      Funny I buy from both and never have seen those but copylite had them! Thanks!
      • Oystercopy
        • Oct 2009
        • 623
        I've been buying my belts and blades from eBay. Seem to be working out good.
        OC
        • copier tech
          • 8144
          The blades are only a temporary fix as once the belt is worn you'll still get lines.
          • mrfuser
            • 1617
            True, most of my clients are low volume so they last a good while. Thanks again!
            • rrrohan
              • Sep 2011
              • 1977
              Didnt KM recently make the cleaning unit on belt a assembly you can order in?
              Sent from my Pixel 4 XL using Tapatalk
