BH-C-280, my own old beast for testing purposes, stuck on logo
  • Hansoon
    • Sep 2007
    • 3350
    Have this old machine for testing purposes only. It started with several error indications regarding the hard drive. After replacing and formatting a new HD the machine came up first with an endless "Now Warming Up" indication. After restarting, everything sounded as normal, the buzzing of the pressure roller retraction motor, the clacking noise of the IDC registration shutter and the usual final beep. Then after that the hourglass the display came on followed with a freezing KonicaMinolta logo and without continuing. Installing fresh firmware was of course not possible either.
    NVRAM? Boards? Never had this error until now with all of my machines of this series. Any help please?
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
  • copier tech
    • 8105
    Re: BH-C-280, my own old beast for testing purposes, stuck on logo
    Hans
    Was the device working OK before you replaced the HDD ?
    Have you tried updating the firmware?
    Can you enter 'trouble reset' mode ? (Hold down counter/utility button & power on)
      • 22942
      I've had other machine freeze up with the black screen at boot up. It was new page memory that finally got me a screen ... and an error code that I could address. =^..^=
      • copyman
        Owner / Technician
        • Sep 2005
        • 4539
        NVRAM? There is a C220 series NVRAM reset firmware. PM me if you need it and will send it to you.
        • Hansoon
          • Sep 2007
          • 3350
          Thanks, I have "A0ED0Y0-F000-GQ7-D1.exe" Is that what you mean?
          Hans
          • copyman
            Owner / Technician
            • Sep 2005
            • 4539
            Hans
            No it's a .tar file
            "A0EDFW.tar"
            • Hansoon
              • Sep 2007
              • 3350
              No it's a .tar file
              "A0EDFW.tar"
              Yeah, that's the one I have. Thanks, Pal.
              Hans
              • Oystercopy
                • Oct 2009
                • 618
                I'm going out on a limb here, but is there a chance that any of the Drum units are past their life? I've had machines freeze up when that happens, even if you have the machine set to go past the life of the drums?
                OC
                • tsbservice
                  Field tech
                  • 7924
                  Hans
                  No it's a .tar file
                  "A0EDFW.tar"
                  Those are the same guys
                  @Hans read carefully firmware update sheet(DLBT1202214EN00) before doing this jig firmware for resetting NVRAM data.
                  • Hansoon
                    • Sep 2007
                    • 3350
                    Machine is working again, still with the original HD and NVRAM.
                    I was not able to update FW nor do NVRAM reset. It came up in between with a C-6752 code pointing me to a bad connected CCD. Found that the screws of the fat connector of the CCD harness going into the MFP board (left side of PWB box) were loose. (big boob of my colleagues) Reseating the connector properly solved all problems suddenly. Though I see no direct relation to the previous problems with this loose connector, reseating and tightening those screws seems to fix the problem for the moment.
                    Thanks for your help, guys.
                    Hans
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4539
                      Thanks for posting the "fix"
                      I've seen several times when machine is locked up that if you can get machine to code out for something else it gets machine working again. One of those fluke things with no explanation.
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4539
                        Thanks for the follow-up
