Bizhub 423 - Constant hissing / static from fax speaker
  • Fritzy
    • Oct 2022
    • 51
    The Bizhub 423 I'm working on has a constant hissing / static noise coming from the fax speaker. The noise starts as soon as the system boots up and the initial 'Ready to copy' screen comes up. The noise is very faint, but is audible from 15 feet away in a quiet room. If I put my finger on the speaker it gets quieter, so it is definitely the source of the noise.
    I have the Line Monitor Sound Fax setting turned OFF, and the send and receive volumes set to zero (see attached photo). The noise also persists even when the sub power switch on the control panel is turned OFF.
    Any thoughts on what I can do to quiet the speaker? I'm considering unplugging it, but if there is a better option, please let me know.
    Thanks!
  • Hansoon
    • Sep 2007
    • 3350
    Re: Bizhub 423 - Constant hissing / static from fax speaker
    I had once one doing this and only replacing the faxboard cured the problem.
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
    • emujo2
      • Mar 2017
      • 1580
      Put the machine into fax mode and touch the off hook button. Does the hissing noise change to what you would expect with a audible dial tone, or is it the same. Does the fax work? What happens if you deinstall or isolate the fax? E
      • Fritzy
        • Oct 2022
        • 51
        Hans
        Good idea - I forgot I had another fax board to try. However, even with this new board I hear the same noise.
        I tried off-hook and on-hook, makes a click sound but then the same noise is present. The fax does work, but has send/receive errors about 10% of the time. I also tried unplugging the phone line, but the noise remains.
        I disconnected the USB cable and gray multi-wire cable from the fax board and the sound goes away! (but so does the fax capability ).
        • emujo2
          • Mar 2017
          • 1580
          Not sure if you were aware of this, but KM made a special 2 wire fax line for this. The 4 wire caused some issues. Also, are you 100% sure this is an analog fax line and not digital or VOIP? E
          • Fritzy
            • Oct 2022
            • 51
            Thanks for the additional information. The noise is present even when there is no fax line attached. However, out of curiosity, I did try attaching a 2-wire fax line and it still makes the same noise.
            I am using a VOIP line. An analog POTS line isn't an option here, so I'm aware that there will be faxing challenges due to this.
            • allan
              RTFM!!
              • 5459
              What happens if you initialize the fax function?
              Whatever
              • femaster
                • May 2011
                • 1466
                Is the ferrite choke attached to the wire harness for the fax board? Not sure if this would help with static noise, as the chokes are designed to help eliminate RF noise, but who knows.
                • Synthohol
                  Certified Konica Expert
                  • 5740
                  fwiw, check the neutral to ground at the wall socket. if more than half a volt id find another power source.
                  also is it right under a fluorescent light or wireless repeater?
                  ive seen cell phones when in use near the machine cause speaker noise. that was a ricoh but still.
                    • 22942
                    Me? I'd just unplug the speaker and call it a day. =^..^=
                    • allan
                      RTFM!!
                      • 5459
                      There should be a soft switch for the monitor function.
                      Whatever
                      • KeviM
                        • Oct 2019
                        • 324
                        If all else failed that's what I would do as well 😁
                        • KeviM
                          • Oct 2019
                          • 324
                          Sounds like 1 of 3 things
                          1) try a firmware update and hope it corrects it
                          2) replaced the fax/line board or repair it. Might have a damaged solenoid
                          3) maybe try a POTS filter on the fax line before replacing the board
                          All the best friend
                          • Fritzy
                            • Oct 2022
                            • 51
                            Thanks for all the additional replies! I took a bit of a Bizhub-break over the holidays so I'm just seeing these now. Here are a some responses to your suggestions:
                            I haven't tried that yet. I just recently got the fax function to mostly-work. I'm hesitant to reset everything now since I'm not 100% sure what settings I changed and I suspect initializing will un-do everything I've done so far.
                            Good suggestion. Yes, the ferrite choke is attached to the wire harness for the fax board. I had a couple clip-on ferrite chokes, so I tried adding one to the USB cable as well, but it made no difference. Still the same noise
                            I will check the line voltage - another good suggestion. Lights are LED. I unplugged everything else in the room - including a WiFi access point that I thought might be the culprit, but no difference. same static noise.
                            All the best friend
                            1. I'm at the most current firmware (as far as I know). I don't have access to all the KM support documentation/firmwares website, so I can't research every firmware patch that might be related to fax.
                            2. I tried another fax board I purchased on eBay - exactly same result with the noise.
                            3. Will need to try to find a filter. I used to have some DSL-line filters, maybe I'll dig one of those up and see if there is any change.
                            Yup. That's where I'm at. While it irks me that I can't figure out what is causing the noise and solve it, I decided to punt and added a 'Fax Monitor' button that connects/disconnects the speaker. Works great for those times when you want to monitor the FAX tones, and eliminates all static noise when disengaged (see attached).
                            I'll look into this, but for now the fax monitor button I added is achieving the needed result.
                            Thanks again to you all for taking the time to address the issue. If I make any additional discoveries as to the root cause of the issue (and resolution), I will let you know!
                              • 22942
                              Nice touch. Even a label. =^..^=
