We have the Konica 7022 in our church. Months ago we had an external power problem from the electric company. When turned on, the ladies found the error: F 36 2 and to call for service. Tried another forum and was told to hold down 25 while you turn on the machine, then the menu screen will display list, use ^ and V key to "select dip switch 3 pick bit 1 then change value 1 to 0" turn off power and back on, it will reset for you. I got everything except realizing there is a format to selecting the dip switch sequence and which bit I'm looking for.
I advanced through the screen and thought I selected the 3rd one and then changed the only 1 in the string to a 0.....then powered off/on and got the new error F-51-4. Looking for advice.
