Bizhub 363 Vendor Unit
  • wkwar
    • Jan 2019
    • 61
    Went to purchase a bizhub 363. Once the unit it powers up it display " install vendor unit" ? not much details other than i am guessing it is lock? can it be unlock? thanks
  • Synthohol
    Certified Konica Expert
    • 5740
    [Administrator Settings] → [Security Setting] → [Enhanced Security Mode][Administrator Settings] → [User Authentication/Account Track] → [External Server Settings][Service Mode] → [Billing Setting] → [Management Function Choice]
    • wkwar
      • Jan 2019
      • 61
      Re: Bizhub 363 Vendor Unit
      thanks for the info. i am assuming they would have set a special admin password so someone cannot go in there just to change it. anyway to reset the machine to factory default?
      • Synthohol
        • 5740
        nah, just make the vendor change in svc mode.
        also admin password can be changed from service mode.
        • wkwar
          • Jan 2019
          • 61
          great , thanks for your help
          • wkwar
            • Jan 2019
            • 61
            pick them up today and cleared the code. ran a copy and now repeated paper jam. one machine jams as the paper tries to go thru the fuser. which roller is missing up?
            the other jams partially as it comes out of the tray. threw a code C-4101. This errors points to polygon motor rotation trouble. when i look at the manual, it ask to check connector and replace PH or PRCB......?
            • wkwar
              • Jan 2019
              • 61
              on the machine with the paper jam, the paper is stuck before the exit section. the paper never makes thru the exit section. swap the exit section with the other copier and still the same. did observe the stepper motor does move. is it the timing belt slipping or something else? the jam code is 11
              • Synthohol
                • 5740
                yeah any 2 digit codes are useless pretty much, its the J+4 digit code that tells where the problem was detected or by what.
                please post the last few.
                • wkwar
                  • Jan 2019
                  • 61
                  multiple 3003 jam code.
                  looking at the manual does not tell me much. however it looks like the paper code is cause by PS3 not seeing the paper. That makes sense as the paper could not get thru the exit section.
                  • Synthohol
                    • 5740
                    take out the fuser, it should spin fairly easily.
                    • wkwar
                      • Jan 2019
                      • 61
                      paper pass thru the fuser but will not go thru the exit section. it makes an accordian between the fuser and exit section. so fuser is good correct?
                      • femaster
                        • May 2011
                        • 1469
                        When removing the accordioned paper, is the paper stuck under any of the 5 picks that ride on the teflon coated roller in the fusing unit?
                        • tsbservice
                          Field tech
                          • 7926
                          Duplex or single sided?
                          • Synthohol
                            • 5740
                            you can only check the fuser bearings with the fuser in your hands, cant check it properly while still in the copier.
                            a good telltale is when you take out the fuser and a line of orange dust winds up on your pants or the floor. thats a bad fuser
                            • tsbservice
                              Field tech
                              • 7926
                              It's usually more brownish in my cases but yea half spoon of rust equals dead fuser in my eyes.
