SD-506 Bundle Press Assembly
  • wjurls
    • Feb 2017
    • 492
    Anyone know if the chain type bundle press is a direct replacement for the older belt type? I recently swapped a press assembly out on a customers SD-506 and while that fixed the jamming issue, now it won't trim. The booklets are blocked trying to go into the trimmer. I suspect I ef'd something up in the process, but just want to confirm that the units are compatible before I start pissing into the wind trying to correct it.
  • Ziggy
    • Feb 2018
    • 684
    Re: SD-506 Bundle Press Assembly
    Attaching a bulletin that show's what needs to be changed to convert from belt to chain. So I would say if you have a chain unit you should be able just to swap it. There is also a video on how to pull bundle press which could show you what you might have missed . If you need video just let me know your email adddress
    • wjurls
      • Feb 2017
      • 492
      Thanks, that's what I figured. I have reviewed that video a few times. I probably screwed something up in the procedure. Maybe a slipped cable or something.
