c450 fuser unit reset
  • cantonakis
    • 19
    Does anyone know how to reset a c450 fuser unit ?
  • LAKY
    • Mar 2009
    • 16
    c 450
    • crm.84
      • Mar 2009
      • 15
      1-Open right side door and remove inside front cover for 12 pin black connector.
      2-Place a jumper between pins 1 and 2 green wires. Make sure jumper wire is thin ie staple, thin paper clip, etc.
      3-Close door and power up the machine-wait until the basic screen comes up then immediately turn machine off.
      4-Remove jumper and power up machine and check fuser life counter-
      May have to do this more than once as you have to catch the machine just as the basic screen shows before shutting off. My first time it took me 3 attempts before I got it.
      works on 350, 351, and 450
      • higherlevel
        • Aug 2006
        • 30
        Fuser Reset ??
        YOUR TALKING ABOUT BLACK AND WHITE MACHINES HERE AS C450 IS COLOR !!
        This Reset should work for C350 also !!
        • pepper38_cnd
          Field Service Manager
          • Aug 2005
          • 1075
          Replace the pico fuse, shorting pins is a dangerous practice. If you can't afford the fuser you probably can't afford the board you risk blowing.
          Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
          Now into Ip TV KODI Boxes
          • ck1
            • 485
            i Agree with you pepper38
            • cantonakis
              • 19
              ok I used the jumper method and worked fine
              Many Thanks to all of you
              • sulemandw
                • Sep 2011
                • 19
                Re: c450 fuser unit reset
                from which way between 1 and 2 pin just clear this confusion
                thanks
