Bizhub C10 "Please wait"
  • llla
    • Jun 2009
    • 8
    Hi.
    I have a bizhub C10 with the message "please wait" stuck i display. Engine and fan`s starting up but "Please wait" msg stuck in display.
  • jprecht
    • Dec 2008
    • 104
    wait indie
    when u pwr up do you see fuser lmp and hear cycling??? copier cycles then stops? may need to replace hdd and/or reflash firmware. have seen this on bizhub c250 good luck!!!! jprecht p s did you "re-initialize"??? first not familiar with this unit but have several 250c 350c ect out there.
    IT IS BETTER TO REMAIN QUIET AND BE THOUGHT A FOOL
    THAN TO SPEAK AND REMOVE ALL DOUBT
    • llla
      • Jun 2009
      • 8
      I hear mc i cycles up. I`ll try to rewrite fw to see if that help. Thanks
      • minimerlin
        • 851
        Originally posted by llla
        Hi.
        Was the C10 asking for any units to be changed prior to this indication...sounds like it is trying to carry out a calibration.
        Please do not PM me without asking first.
        • llla
          • Jun 2009
          • 8
          No, costumer had just turned it on and no other msg than "Please wait".
          I tried to wait 10 min but msg was still there. I tried to power it off/on several times but it just starts engine, rotate whats supposed to rotate, I hear fans starting, just like normal. But msg say Please wait. So like jprecht I think it is fw or some electronical problem. I`ll try fw rewrite tomorrow.
          • jprecht
            • Dec 2008
            • 104
            reboot
            not familiar with this one but almost all bizhubs have a service pcb with two pins you short to re-initialize short pins cheat door sw depress service trouble reset button hold it down while turning on copier wait 10 sec, release i would try this first . good luck!!!
            • llla
              • Jun 2009
              • 8
              I loaded new fw today but mc still show same msg, but I saw that exp lamp did not light up so I`ll try to change CCD assy.
              • tarzak911
                • 55
                not ccd ... fuser lamp...
                • peter lynn
                  • Dec 2007
                  • 27
                  Hi.
                  the fuser is fed via a microswitc h operated by a plunger/on left side top covercheck pivot point ofthis operating lever--it breaks--and replace the switch (same as front door switch on 7033/7045)
                  you wll kiss goodbye to 2 hours for this.(follow change fuser instructions for access)
                  happy copying peter
                  • tech51
                    • 846
                    Your spot on with the ccd/lamp assembly, just had a tech memo saying this is probable cause of please wait message. Go for it!!!
                    • xeroprint
                      • Nov 2008
                      • 20
                      I have this same problem"please wait" . I change exp lamp and all scaner
                      in c10 from minolta di1610. Its works.
                      • nvram
                        • Jul 2009
                        • 40
                        hi, i have had three units do this too.
                        si
                        • Scorotron Wizard
                          • 28
                          I've got one doing it now, does anyone have a difinative answer?
                          The Wizard
                          To the Pessimist the glass is half empty
                          To the Optimist the glass is half full
                          To the copier engineer...
                          The wrong glass has been supplied, it should be 50% smaller Haha
