Konica 7145 F51-2
  • RookieTech
    • Jun 2008
    • 46
    Konica 7145 F51-2
    Hey guys I have a Konica 7145 with a F51-2 error code, fuser motor error. Anyone have this part number available?
  • copytechman
    • Nov 2008
    • 929
    Better make sure it's the motor (u can swap with other motors w/same pn# in this machine to test!) Cuz sometimes its not... often it is a control board icp failure.. repaired a few of those!
    Pn# is printed right on the motor
    Regards!
    A!
    • mrwho
      Major Asshole!
      • 4299
      DESCRIPTION: F51-02. The fixing motor M11, will not turn in diagnostics. CAUSE: Loss of 24VDC to the Fixing drive motor.
      SOLUTION: Replace the PRCB (p/n 40LA-9029).
      Try this, could be that the motor is OK. Check the ICPS on the PRCB before ordering a new one, as copytechman said.
      Mascan42
      Ibid
      • RookieTech
        • Jun 2008
        • 46
        From a previous post, it was advised to replace the Corona unit in conjunction with the main board. Does this seem logical, or will the main board correct the problem?
