Do you get the code during warmup? Check that the white reference strip on the underside of the platen glass is clean and positioned properly.
It could be a bad exposure lamp. Go into 47 mode, output 00 and the lamp should come on if it's good.
If it happens intermittantly during copy runs it could be the A/D ribbon cable, scanner motor or DC power supply.
