df-608 RADF and c300
  • tobih
    • May 2025
    Hi folks,
    i have the following problem with a DF-608 RADF on a bizhub c300.
    There is a small gap on the left rear side when the DF-608 is closed.
    When i try to scan or copy sheets i have a grey cloud on the upper right corner of the print.
    If i push the df-608 manually down to close the gap, then the printing is ok.
    How can i adjust the two springs on the left of the DF-608 RADF ???
    Help needed - Many thanks for any idea.
    Greetings, Tobias
  • lucky13
    • May 2008
    • 125
    check out page E-5 and E-6 of the install doc height adjustment
    • tobih
      hi lucky13,
      thanks for your support - now it works fine.
      Greetings, Tobias
