Konica Minolta 210 jamming at reg and fuser
  • jonbonse
    • Jun 2009
    • 737
    I have a client with a jamming problem at registration and fuser.
    I have swapped the pickup solenoid with the bypass to cancell it out.
    I swapped the reg sensor and fuser sensor around.
    I am suspecting a possible slipping reg clutch. . . or maybe intermittant dodgy reg sensor or fuser sensor. .
    Has anyone had this on one of these?
    Many thanks
  • Doughboy
    KM Service Engineer
    • Jul 2010
    • 10
    I think i had this on a 210 before, there is what looks like a silver mylar/guide below the drum on the image unit. If this gets too dirty it can cause a static build up which will cause these jams. I cleaned it and got about 4 weeks before it started jamming again. Eventually i gave in and replaced the whole image unit and it cured the fault.
    Hope this helps
    It's a F*****G office copier and you expect Litho Quality?!!!! The salesman is a complete PR***.
