Description
C-6701 (C6701) at power up.
Solution
PROBABLE CAUSES:
1.Failed Overall Control Board (OACB). Check ICP3 on the OACB. If it is OPEN, check for shorts and replace the Overall CB (p/n 50GA -930 3K for bizhub 360 and p/n 50GA-930 1H for bizhub 420/500).
2.A communication issue between the CCD and OACB. This issue usually appears shortly after replacing or removing the OACB (Overall Control Board). Please check the flat cable between the CCD and OACB. Make sure it is undamaged and connected properly. Replace the CCD cable (p/n 50GA 9050 0) if re-seating it has no effect on the service code.
