How to reset a network card in a C452
  • jrf
    • 142
    Hi guys, I have a C452 which i need to reset all network settings on. Anybody know how?
  • jma676
    Expert Tech
    • Mar 2009
    • 324
    Check: User's Guide (Network Administrator)
    • RRodgers
      • Jun 2009
      • 1947
      Hit utility, admin mode, put in admin password then hit network setting, the tcp ip setting. Set them for what ya need and reboot.
      That should do it.
      • jrf
        • 142
        Thanks but I need to reset all settings to default on NIC
        • Stirton.M
          All things Konica Minolta
          • Oct 2009
          • 1804
          And to do that you go into Administrator and access the network settings and erase any and all settings within that.
          Is there any particular reason you want to reset these?
          "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
          ---Groucho Marx
          Please do not PM me for questions related to Konica Minolta hardware.
          I will not answer requests or questions there.
          Please ask in the KM forum for the benefit of others to see the question and give their input.
          • jma676
            Expert Tech
            • Mar 2009
            • 324
            That should do it.
            Thanks Rogers, but I do not ask anything, the other boy (jrf) is concerned.
            • Konica_jr
              • Aug 2010
              • 25
              more radical, use the stools !
              " French do it better " ^^
              • mitchl
                • Apr 2007
                • 501
                The only way to clear a NIC that I know of is to use the NVRAM recovery tool that you install on the flash card, it gives you 2 options when in the machine one to reset the NIC and the other is to recover NVRAM...... Might want to give that a whirl.
                • jma676
                  Expert Tech
                  • Mar 2009
                  • 324
                  as I said before:Check: User's Guide (Network Administrator)
                  You, Maybe, not compose well the question, or want to refer to something else, ooooh... read the manual, if you want to restore any settings, just do it, you want to configure the IP address again, between a new and longer.
                  Anyway.
                  Initializing the configuration information
                  You can initialize the network settings (to the factory defaults), reset the controller, and delete the entire destination information.
                  1-Network Setting Clear:
                  In the administrator mode of PageScope Web Connection, select "Maintenance" - "Reset" - "Network Setting Clear".
                  (If Enhanced Security Mode is enabled, this menu item will not be displayed.)
                  *If you click [Clear], the network settings of this machine are cleared to the factory defaults.
                  2-Reset:
                  In the administrator mode of PageScope Web Connection, select "Maintenance" - "Reset" - "Reset".
                  *If you click [Reset], the controller is reset.
                  • jrf
                    • 142
                    Yes Stirton.M
                    We are running external copy and print control software on device but we are unable to control the +452 at present as some IT guy changed alot of details
                    • RRodgers
                      • Jun 2009
                      • 1947
                      Resetting the nic won't help ya with that. You want to reset the authenication stuff.
                      • Stirton.M
                        • Oct 2009
                        • 1804
                        I agree. This appears to be more to do with copytrack/authentication, which has very little to do with network settings within the machine.
                        When using the internal copytrack/authentication features of the machine, this is independent of any external devices or controls on the network, including the network settings set in administrator mode. Use of the built in copytrack/authentication can be set to allow printing without authentication. This is accessible through administrator mode, authentication settings. By default, it is disabled.
                        The use of external controls is by their very nature are are not a part of the network settings, aside from being present between the MFP and the network to which it is attached. External devices such as Hecons control network access to the print operations, but are independent of the machine.
                        Review the user manuals found on the CD set you got with the machine. The sections in administrator mode, authentication will outline the specifics of the functions of this feature.
                        ---Groucho Marx
                        • jrf
                          • 142
                          Yes i have this i have used this on c250s but i cant find one for a c452
                          • Albonline
                            • Sep 2008
                            • 1133
                            I belive that in tech/rep,system 2 there is an initialize all button to acomplish the desired effect.
                            • jrf
                              • 142
                              Just to let you know that clear all under initialize in service mode is the only way to clear all network settings. There is no novram recover tool as most settings have been removed from the novram. Thanks for all posts
